I've been dealing with a problem for many years with my power steering pump is just a smidge out of alignment and it causes belts to wear on one side, slinging hot rubber all over the engine bay, rolling the belt, and throwing the belt at high RPM. I have a fresh 360 block and fresh brackets. You can see from my pictures that if I put a straight edge across the pulleys I get a 1/8" gap on the inside edge of pulleys. Is this normal? Does anything look out of norm? Would a serpentine setup correct this or just have the same issue?
